Is there a way to customize the automatic numbering routine in Revit (for views) so it can auto-increment letters instead of numbers when you place these on a sheet? I know it does this for column grids, but I'd like to have this work if I place a view on a sheet, change the number to a letter, and have the next view assigned as the next number alphabetically. It does work that way for door numbering.
