Assign combo for pan
6 ANTWORTEN 6
Nachricht 1 von 7
Enricopupi
435 Aufrufe, 6 Antworten
Hi, it' s possible to set the combo alt + right for pan?
It would be so useful! :leicht_lächelndes_Gesicht:
6 ANTWORTEN 6
Nachricht 2 von 7
mauricio_mssf
als Antwort auf: Enricopupi
Unfortunately, the desired combination is not possible.
You can try another one.
Type the shortcut key KS and follow the steps to create a shortcut
If the tool you want to change already has a shortcut key, you can change it by clicking Remove, and creating a new one and clicking in assign.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and like if you liked it.
key.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 3 von 7
Pressing and holding your middle mouse button not working for you?
https://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/20...
Nachricht 4 von 7
Enricopupi
als Antwort auf: mauricio_mssf
Hi Mauricio, thank for your suggest, but I don' t get any feedback in the viewport for the command 'Pan Active View', I 've tried many combination of keyboard shortcuts :enttäuschtes_Gesicht:
Anyway, another way seems to be pretty fine in terms of speed during modeling, pressing Alt + W I can quikly get the SteeringWheels and i can easly pan :grinsendes_Gesicht_mit_lächelnden_Augen:
Nachricht 5 von 7
Enricopupi
als Antwort auf: barthbradley
Hi barthbradley, sure it works.. But the new Microsoft Surface ARC Mouse nicely thought to don' t provide the scroll click anymore :sich_vor_Lachen_auf_dem_Boden_winden:
Nachricht 6 von 7
Too bad. You must of missed the memo from Autodesk/Revit discouraging the Microsoft Surface ARC Mouse.  Learn to use the Wheel then.  I'm not very proficient or nimble  with the Wheel personally, but those that are, look really very cool to me.  Like Nascar drivers. :lächelndes_Gesicht_mit_Sonnenbrille:
Nachricht 7 von 7
