Assign 2x Yes/No Parameter to element
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Mat.Syaf
172 Aufrufe, 2 Antworten
I know we cannot assign 2 same Parameter Type into 1 element but do we have workaround of it?
The issue is, I have this rack with rear panel that need to turn off or on depend on the type of rack they use. But the thing is, that rack is Array family which mean I have assign yes/no parameter to the rear panel as if the rack is 1 unit, multiple rear panel will off and single rear panel will on. same goes to if more than 1 rack is used, single rear panel will off and mutiple rear panel will on. Now, we have type of racks and some of the type does not need rear panel at all.
Does anyone have an idea?
2 ANTWORTEN 2
Nachricht 2 von 3
stefan_gokstorp
als Antwort auf: Mat.Syaf
not 100% sure i understand but in general use nested family for arrays. if your entire rear rack is nested use a yes/no parameter to control the visibilty for the entire nested family that way you can control it by type level.
Nachricht 3 von 3
Mat.Syaf
als Antwort auf: stefan_gokstorp
Yess. Its worked! make the Rear Panel as a nested family and add yes/no parameter, load into Rack family, setup array like usual then select the nested Rear Panel, link the yes/no parameter to the new yes/no parameter in the Rack family. Now the Rear Panel will work as array (single or multilple unit) and can be on off its visibility.
Thanks @stefan_gokstorp !
