Hi Guys,
Could you please help me about the assembly view. I have created assembly for the kitchen typical type for documentation. But I cannot use any tool on Modify tab as align, trim, e.t.c in below. Anyone can tell that why and anyway to solve that ?
Thanks so much.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You have to select the assembly to choose Edit Assembly, you'll find the tools become enabled again. The assembly views aren't really expecting you to alter the assembly. Assemblies are quite different from Groups.
Steve Stafford
The explanations and workarounds are ok, but it would be better if Revit could understand the context of annotation vs. modeling, in this situation. Adding a simple filled region or detail lines become unexpectedly cumbersome.
This is insane. I use assemblies to detail millwork. I need to use the tools, what is the reason for this pedantic block of all the tools?
