Assembly Dimensions
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1498 Aufrufe, 2 Antworten
Assembly Dimensions
Hi everyone, I'm new to Revit. I've created my first stud assembly. Do I have to dimension the assembly frame manually or is there a setting so Revit would automatically dimension it for me?
Mark
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: Anonymous
@Anonymous
There is no OOTB Revit feature that allows to dimension the whole assembly automatically. You can workaround certain feature to ease the process (such as automatically dimensioning grids) but if you want everything dimensioned with ONE CLICK you need to use
  1. either plug-in (you can check the Autodesk App Store https://apps.autodesk.com/RVT/en/Home/Index)
  2. put a graph in dynamo that does it (you can look on Dynamobim.org forum for assistance)
Nachricht 3 von 3
als Antwort auf: RDAOU
Thanks for your help.
Cheers
Mark
