Assemble create view unhide top elements
11 ANTWORTEN 11
Nachricht 1 von 12
qixing.chenNYA88
464 Aufrufe, 11 Antworten
I create an assembly and used create view. However, the top elements are hided in the view. Could anyone help with this?
Very appreciate your help!
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: qixing.chenNYA88
You mean it's cut off in Elevation Top View?
Nachricht 3 von 12
qixing.chenNYA88
als Antwort auf: barthbradley
Yes, I think so.
Nachricht 4 von 12
Was the top included in the Assembly? If not, then Edit and Add it.
BTW: This is what I mean by "Top" View:
Nachricht 5 von 12
qixing.chenNYA88
I think I misunderstand what you said. I want to created a 3D view of the assembly however the top elements are not visible from the view. Do you know what setting I should change? The first picture has covers and they disappear in the 3D view.
Nachricht 6 von 12
Were you including the cover when creating the assembly?  No.  Just edit the assembly and add it in.
Nachricht 7 von 12
qixing.chenNYA88
als Antwort auf: ToanDN
Yes, the top covers are in the assembly.
Nachricht 8 von 12
How would you know? In which assembly views do you see it?
Nachricht 9 von 12
What's the name of the Assembly View you are in?
Nachricht 10 von 12
qixing.chenNYA88
It's the 3D view. I found out the solution and it worked. The cover is a nested family in the frame and I recreated it in the Frame's family.
Nachricht 11 von 12
The nested family is shared.  You could keep it as is, just add it to the assembly by using TAB to select it.
Nachricht 12 von 12
So basically, it's a Shared Family that is NOT added to the Assembly.  So, Add it then.
