As-noted - how do I change this parameter in the title block?
5 ANTWORTEN 5
Nachricht 1 von 6
2593 Aufrufe, 5 Antworten
So When I have multiple scale sizes on a title block, my titleblock changes the scale box from a scale to "As noted".  Where can I change this parameter?  I would like to change it to something else.  I checked the title block label in the family but it wasn't completely obvious where this is set.  Please advise.
Thanks in advance.
Regards Peter.
5 ANTWORTEN 5
Nachricht 2 von 6
Kimtaurus
als Antwort auf: Anonymous
One solution is to create a new parameter and fill in the scale manually.
(Not perfect though, 'cause you can forget to insert the scale or insert the wrong scale)
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 3 von 6
David_W_Koch
If you need to change it, @Kimtaurus's suggestion is the best you can do.  The out-of-the-box parameter is not user editable.  See this thread for a lengthy discussion of this.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 4 von 6
chrisplyler
I'm usually annoyed by things that are hard coded instead of user-editable. But why would you want to change the default behavior in this case? If you have multiple views on a sheet, and those views are at different scales, why would you want the sheet's scale property to just list one scale?
Nachricht 5 von 6
David_W_Koch
als Antwort auf: chrisplyler
I cannot speak for @Anonymous, but the issue for me is not trying to display just one scale, it is with the default text and its formatting, neither of which conform to my office's standards.  We would want to see AS NOTED not As Indicated.  Not a big deal (not losing sleep over it), but I cannot think of a reason why there could not be a project parameter exposed to the end user to hold the value displayed when there are multiple scales involved.
File under "Small Enhancements".
David Koch
Blog | LinkedIn
Nachricht 6 von 6
I don't want to change the behaviour. I want to change the actual text that shows. Currently it is lower case. I would like to make it upper case as all of the other text in the titleblock is upper case. Also I would like it to say AS SHOWN, not As noted. That's pretty much it!
Exactly as David said!
Cheers Peter.
