Artificial Light 360 degree
Hi, I want to create a Light that emits towards all directions. Ive tried with the tilt angle but it seems I can only go up to 180°. I need 360°. Is there a way to achieve this?
Please see images attached. 1. Light I have. 2. Light I want to achieve.
L.Maas
Edit the family and select the light source. Then edit the light source definition.
Then select point light and choose (hemi)spherical.
Louis
Please mention Revit version, especially when uploading Revit files.
Sounds like you are describing Beam Angle.  Widen that Angle.
Great, but for some reason my parameters are greyed out, do you know why that is?
Thanks!
Great knowledge!
