Array
This widget could not be displayed.
Array
Hi all. I have created a mass , then made solid and arrayed / number 14 but I only see one.
If selected I can see the number 14 but cannot see the other. Help appreciated thanks.
Replies (7)
dzanta
is "Show Mass Form and Floors" turned on?
is your array measurement from first to second or first to last?
i made a generic mass object in the conceptual massing environment, loaded it into a default arch template and arrayed it 14 times and it shows fine.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
1. Yes, mass is shown on visibility
2. From first to second
3. I did it before and worked and showed fine but don't know why on this case displays the number 14 but actually show only one..
dzanta
can you test the behavior on a new default arch template file and a generic mass?  I want to see if it is a software issue or a file issue.  Thanks.
Is your View cropped?
you mean array view or general view?
General view seems fine as I see other objects around..
no solution for this it seems
dzanta
send me your revit model so i can look at it asap
