Array will not constrain.
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
jwya0001
532 Aufrufe, 4 Antworten
Hey, hope you are travelling well.
I am constructing a simple shelf unit family. However when I lock and array the shelves to the left and right reference lines, they do not constrain when I adjust the width of the shelf (seen below). These shelves are nested and have instance parameters. I have also attached the rfa file. Any help will be greatly apprecitated!
Best, Jarryd
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: jwya0001
Constrain the second element in the array to a vertical ref plane.
Nachricht 3 von 5
jwya0001
als Antwort auf: ToanDN
Hi  ToanDN,
Thanks for the suggestion, the shelves now move when I adjust the width, but they dont stretch even when I constrain them on both sides?
Thanks again,
Jarryd
Nachricht 4 von 5
I would create the shelf as a family with instance width parameter, nest it in the main family, associate width parameter, and array it.
Nachricht 5 von 5
jwya0001
Brilliant, it works. Thank you so much!
