Array on sloped toposolid
aergunWHHWD
aergunWHHWD
I am designing a winery for a studio class, I want to array the vineyard's vines around my building in Revit. I have the vines 3d modeled as a component, but I want to have them arrayed in straight lines, that match the site's slope. Any suggestions? a.png
If you want to draw lines on the toposolid then modify sub-elements and add split lines.  Might want to add some reference planes first so that you can draw the split lines correctly.
Another way is using railing hosted by the toposolid and utilize balusters for arrayed elements.
Similarly, model a curtain wall and attach its base to the toposolid, then utilize vertical mullions and/or custom curtain panel family for arrayed elements.
