Array Issue in family
3 ANTWORTEN 3
Nachricht 1 von 4
397 Aufrufe, 3 Antworten
I am trying to create a pigeon hole casework and have arrayed the vertical dividers but cannot get the formula to work for the Horizontal Adj shelf. They are both families that I have loaded in and arrayed. Revit says that it cannot find solution for formula.
Any suggestions?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
You're mixing type and instance parameters.  Try changing those to Type.
Nachricht 3 von 4
hmunsell
id start by narrowing down where the issue is. if you remove the 2 array and 2 Divider formulas, does the basic No of... parameters work? if they do, then the issue id with the Devider/Array formulas.
like @Anonymous suggests set all your parameters your using in formulas to the same class, either all Type or all Instance.
Howard Munsell
Nachricht 4 von 4
RDAOU
@Anonymous
Using a Type parameter in a formula driving an Instance parameter in the host family shouldn't be a problem...The error implies that a formula in the nested families is not satisfied by the formulas defined in the host...Edit the nested families and if you have any formulas, remove them
