Array component with rotation
HeadbuttJ
Message 1 of 11
HeadbuttJ
I created a frame which is a component created by model in place around a hole with sweep function. I wanted to array the component to every hole. After array, the components did not rotate and even broke apart.
Anyone can give me some solutions? Thanks!
Replies (10)
Message 2 of 11
Radial Array?
Message 3 of 11
HeadbuttJ
Yes, radial array
Message 4 of 11
Post the file.
Message 5 of 11
HeadbuttJ
The file is attached.
Message 6 of 11
HeadbuttJ
Do you have any solution?
Message 7 of 11
I would build the trim into a window family, load and place an instance of that family on the project wall, and then radial array it.
Message 8 of 11
Mohamed-Nassar
Take base in the middle of the radial array and write it in the upper line which is Green, if this method didn't work try to close Revit and reopen it again and try.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 9 of 11
Example: M_Window-Double-Hung Arrayed.
Message 10 of 11
L.Maas
It is possible to do this in th project
However i would be eassier and more efficent if you first created a loadbale family.
In general consider one offs for in place families. As soon as you create several instances you should be better off with loadable families
In your case when you go to edit inplace family and you select one of the sweeps you will see this
This means this sweep is connected to a workplane, preventing it to rotate.
When you click on it this associaion is removed and you can rotate the object
Louis
Please mention Revit version, especially when uploading Revit files.
Message 11 of 11
HeadbuttJ
Thanks!! it works perfectly!!
