I have sloped roof over the room, which consists of two separately made roof objects, one above another. It is to divide roof finish (which is common for whole building) and insulation layers (which differs in different parts).
I want to use Areabook Extension for calculating Living Area based on 2 heightlines.
Now, the room itself automatically sees the first lower roof correctly and stops calculation on it, giving me proper volume value. That is great.
But the Areabook extension does not care about it and takes the upper roof as a reference, which makes the heightlines calculation bad, as I had higher room.
Can I force the extension to calculate with the lower roof in any way?
