Area Schemes with design options
In an effort to create different area schemes to match the architecture changes in my design options, why can’t you duplicate one area scheme to another? Or copy areas from one scheme to another? Is there an alternate method of showing what I’m after?
coffeyj
Hi JmyersRTKL,
Thank you for participating in Revit Answer Day! Currently Areas and Area Boundaries are not allowed in Design Options. If you would like to document this information in Design Options, make an Area Scheme and an Area Plan for eeach option and then draw all Areas and Area Boundaries in that view.
Thanks again!
The problem I have with this is that if I want to do several different Area Schemes, all mostly similar, but each one with some slight modifications to them, I have to build each one entirely from scratch! This is a waste of time. The only way around this is to save as a new file, which is archaic and against what Revit is about.
I've instead been doing a work around with using Floors instead of areas to have the ability to impliment design options as well as using phasing. Then I use custom filters to make categories of floors different colors. It's much more free. The only downside is that Floor Tags do not have the ability to include their area parameter into the tag. There seems to be several instances in Revit where you cannot pick certain system family instance parameters for tagging.
Hope that makes sense.
