Area schedule formatting
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
669 Aufrufe, 7 Antworten
This seems like it should be a basic function, but I cannot find anything that tells me how to do it.
In short, I want to have an area schedule that has my Gross Building Area and my Exterior Area for the same unit side by side, not underneath each other.  I've posted 2 screenshots - 1 of what I have in revit, and 1 of what I would ideally like, created in excel.
Help?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Nachricht 3 von 8
als Antwort auf: barthbradley
Hi @barthbradley
I did have a look at this video (and many others) before posting, but it doesn't cover my issue.  The issue is, I want Gross Building Area and External Area (and ideally, the total of the two) side by side in a schedule, not underneath each other.  Almost as if the individual columns were filtered to show each type, I suppose.  I'm sure there has to be a way of doing it, but I can't figure it out.
Nachricht 4 von 8
no, there isn't any way to do that.
...post your file.
Nachricht 5 von 8
Sure you can.  See attached Revit 2022 file.
Nachricht 6 von 8
als Antwort auf: ToanDN
@ToanDN unfortunately I'm still in Revit 2020 and can't open the file, but I am VERY KEEN to know how you did that!!
Nachricht 7 von 8
- Add a Yes/No parameter (Exterior) to the schedule
- Check boxes for Exterior rooms and clear boxes for Interior rooms
- Add Calculated Value parameter: Exterior Area = if(Exterior, Area, 0 m²)
- Add Calculated Value parameter: Interior Area = if( Exterior, 0 m², Area)
- Format Area, Exterior Area, Interior Area to Calculate Totals
Nachricht 8 von 8
Thank you, this fixes it exactly!!  Great solution.
