Area plan Color fill pattern appears as diagonal lines in Revit 2024
3 ANTWORTEN 3
Nachricht 1 von 4
shane.david
399 Aufrufe, 3 Antworten
Has anyone come across an issue like this before?
On Code Area Plans the solid fill pattern appears as a diagonal hatch, please see the attachment.
Beschriftungen (4)
3 ANTWORTEN 3
Nachricht 2 von 4
SteveKStafford
als Antwort auf: shane.david
Check the Fill Pattern assigned to the Color Scheme you are using.
Steve Stafford
Nachricht 3 von 4
Can you show the Area Color Scheme setting window?  And trying to assign the view to a different color scheme, OK, then back to this color scheme.
Nachricht 4 von 4
shane.david
als Antwort auf: ToanDN
Thank you for the responses. @ToanDN as you will see from the posted jpegs, I changed the color scheme without any change to the fill pattern. That led me to take a closer look at the filters and systematically turn them off and on to see if any of them would correct the issue. I found one for areas that are not in contract that when disabled corrected the solid fill pattern of the area plan. I have posted a jpeg of the resolved plans.
Thank you again to both @ToanDN and @SteveKStafford for your responses and questions.
-Shane
