What is the best way to draw an Area of Work box? I can use detail lines & text, but is there a tool that is designed for this purpose? Image attached.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
You can use Match Lines so that they appear on more than one views without copy pasting. Some other tools:
- Area plan
- Property lines
- In place Mass (if you need to show it in 3D)
You can use generic annotation to highlight the area. See attached
@julielfifield wrote:What is the best way to draw an Area of Work box? I can use detail lines & text, but is there a tool that is designed for this purpose? Image attached.
Looks like a Callout to me.
....Callouts have been used since caveman times. Of course, they weren't called "Callouts" then. I think they referred to than as "ERRGS"
I've created fonts base on Architectural bubble. You can create text and then type in A-K just to get different shape.
