Area Deduction Schedule
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1828 Aufrufe, 3 Antworten
i have 2 area schedules, one is gross floor area, the other is deduction area.
i was wondering if i can combine them together and get the right amount in total,
example; gross area 1700 sqft - deduction area 150 sqft = total 1550sqft
thank you.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Add a parameter to enter the deducted value to the Gross Floor Are schedule, and add a Calculated value to do the math for you.
- You have to manually match up and update the value from the Deduction Area schedule to the new parameter above
- Or you can create a Dynamo script to so it for you if they are constantly changing and/or there are many
Nachricht 3 von 4
Sahay_R
Is Deduction Area a formula driven project parameter associated in the project to Areas? Is it not included when you create the schedule?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 4
als Antwort auf: ToanDN
Unfortunately there's a better way of doing it!
i created a Yes/No Parameter called Deductible,
then i created a Calculated Value that goes like this;
and then you show the total calculation for it and then you see this;
ta-da!!!!
so with all the respect to Dynamo, we don't need it for now.
