Architectural column visibility
5 ANTWORTEN 5
Nachricht 1 von 6
s.karuppuswamy
356 Aufrufe, 5 Antworten
Hi everybody
i am using revit 2020, create a arch discipline column
i will edit the column in type property edit
parameter graphics  -coarse scale fill as magenta
material and finishes also cut pattern also magenta
but it not displaying in model plan screen
kindly give any one solution
thanks
Tags (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: s.karuppuswamy
Set the view to Coarse.
Coarse Scale Fill Pattern = Solid Fill
Nachricht 3 von 6
s.karuppuswamy
als Antwort auf: ToanDN
hi sir
its not happened
Nachricht 4 von 6
Make sure the view range cutting the columns.
Share the model here.
Nachricht 5 von 6
s.karuppuswamy
some of the grid location have visible solid color
but not all ,why
Nachricht 6 von 6
curtisridenour
set the phase filter to None.
