Architectural column paint + material takeoff
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
elias_munoz_neyra
1393 Aufrufe, 5 Antworten
Greetings,
I've been working on this assignment and I was preparing the schedule for paint and applied paint on several families. I've come to realize that architectural columns won't give any results and I was wondering if there's a way to calculate the painted area on columns like on walls, for example, after adding or splitting the face.
Thanks in advance for your time.
Kind regards
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: elias_munoz_neyra
Did you Paint the Columns?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
...if you have painted columns, Material as Paint should read "No". Perhaps, the Schedule is reporting the wrong Phase.
Nachricht 3 von 6
L.Maas
Can you upload your project?
I see both painted materials and the actual material on a (structural) column
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 4 von 6
elias_munoz_neyra
als Antwort auf: L.Maas
Thank you very much for sharing the image it answered my question.
I've realized that though the face is painted, it isn't a yes in the "Material: as paint" parameter; but its name does appear in the "Material: Name" parameter. I'll filter by name and it should be good to go.
Thanks for taking the time to answer this question.
Nachricht 5 von 6
elias_munoz_neyra
One last question: Why doesnt the parameter "Material: as paint" change to yes in columns?
