Architect Struggling with Pipes
9 ANTWORTEN 9
Nachricht 1 von 10
IMCornish
565 Aufrufe, 9 Antworten
I am really losing it as I try to make a 3D plumbing layout appear as a previous one that I had done.  If you study the two screen 'snips' below you will see one which is clear and one that is weirdly transparent and has jagged lines everywhere.  Both views are using the same View Template, Pipe Systems, etc yet I cannot correct the second!  Someone help please....
1 As I would like it:
2.  The one I am pulling my hair out over:
Thank you 
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
9 ANTWORTEN 9
Nachricht 2 von 10
RobDraw
als Antwort auf: IMCornish
Check the view template to make sure everything is checked. Something is different between the views that is not being controlled by the template. It looks like scale and visual style, and possibly more.
Rob
Nachricht 3 von 10
Discipline?
Nachricht 4 von 10
Unload CAD links.
Nachricht 5 von 10
 In the view template properties:
-check if "model display" is set to any transparent value, set it to zero
-Check out if "v/g overrides model" or the one below "v/g overrides annotations" are included, change to not included
-set view template to "none", enter ok, press "vv" and check again if "model display" is set to any transparent value
You can specify a view template by deactivating it, setting it to "no view template", press ok, then you do an overwriting using "vv" on the keyboard, change the view template settings and then set it back to the normal usual view setting. So you use the defined setting but it is overwritten by the "vv" command.
Nachricht 6 von 10
IMCornish
als Antwort auf: barthbradley
Have tried that with no changes....
Andrew Robertson
Chartered Architect
Truro. UK
Nachricht 7 von 10
IMCornish
als Antwort auf: ToanDN
There are no CAD links, just a Revit link. Have tried removing that but no changes.....
Andrew Robertson
Chartered Architect
Truro. UK
Nachricht 8 von 10
IMCornish
als Antwort auf: Anonymous
Although I do not understand what you explain in your last paragraph I have tried all you have said with no improvement......thanks anyway, much appreciated
Andrew Robertson
Chartered Architect
Truro. UK
Nachricht 9 von 10
RobDraw
Since you have not responded to my post, share the model to stop the guessing.
Rob
Nachricht 10 von 10
IMCornish
als Antwort auf: RobDraw
Apologies, I missed your response and am still struggling with this.
Pipes are my worst nightmare! I will try what you suggest and let you
know.
Andrew Robertson
Chartered Architect
Truro. UK
