Revit hangs up when opening a central Revit model
Hey guys, Hope everyone is doing well
I'm having trouble with the Revit model
The model is about twin towers Hotel, it contains 33 typical levels and each level has 12 typical rooms, I Have created 3 models, one model has the typical Rooms and the other model is the typical level which has the typical rooms as a link, and the last model is the master central model which has the typical level as a link, Now those repeated links make the central model hanging and stop working
Please if anyone has experienced this problem, please provide us with a suitable solution
Do the model have workset? I would turn off all workset and only open one to speed up the loading. Then unload the all the link model. Open the workset. Afterward load the link.
