Arc Length of a Sweep Blend
redmondb024
Message 1 of 8
redmondb024
Hello! I have been trying to lay a dimension line for the arc length of a sweep blend I made. It allows me to create an arc length dimension for a normal sweep, but it won't let me for the sweep blend element. I am thinking maybe it has to do with the fact that profiles 1 and 2 don't sit directly on the sketch path like my sweep does?
Any suggestions or advice would be greatly appreciated!
Accepted solutions (3)
Replies (7)
Message 2 of 8
Got pictures?
Message 3 of 8
If the profiles are not on the arc path then the swept blend edge is no longer an arc, but an partial ellipse or a spline curve.  Therefore you cannot place arc length dimension.
Message 4 of 8
redmondb024
Message 5 of 8
redmondb024
Thank you! that clears things up for me for sure. Do you have any recommendations on how to measure the length of it then?
Message 6 of 8
You can get there in an Adaptive Template with a Spline through Points.
Message 7 of 8
You can create a mass in place with ref points along the edge of the swept blend, a spline thru points, and you can have the length.
Message 8 of 8
redmondb024
thank you so much! This really helped.
