Dear all,
It is required to produce structural drawing using a revit model but in Arabic language and i had made some modifications in my system to obtain this requirements .
the problem now is that when i make a spot elevation under zero level it shows me (-1.50), but i need it to be (1.50-)
as Arabic is read from right to left
I remember threads about this in the past. I thought it was said to be corrected in 2017 or 2018. What version are you on?
Strange. I don't even see Arabic as a supported language. You're not by chance using a third-party software for this?
I have no problem to use English interface ,the point is that i want to produce the drawings in Arabic language ,it is possible to do that ,but my problem is the negative sign position relative to the number or value .
