Applying phases
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
331 Aufrufe, 1 Antwort
Applying phases
Why cant I apply phases to plans in Revit 2019. There are all set up but the phase filter drop down menu in the properties panel is greyed out so I cant select it. Any ideas?
1 ANTWORT 1
Nachricht 2 von 2
mauricio_mssf
als Antwort auf: Anonymous
Do you have a Viewtemplate applied?
It appears to be a Viewtemplate applied with the phase filter blocked, if so, go to the view model settings and unchec the indicated option.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
