Applying grid line format to new sheets
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
anson6WA2Y
1067 Aufrufe, 3 Antworten
Hi, here's a quick question on whether there's any way to apply grid line format to new sheets.
I don't want the grid lines to run through the whole drawing, so I switched all the grid lines from 3d to 2d and dragged the end points to the side of the drawing (as shown below). I'm doing that for many sheets, and it's a pain in the ass to align all of them manually. Is there a quick way to apply the same extent of the grid line to the other sheets?
Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: anson6WA2Y
If the plans stack and have the same crop region then you can use Propagate Extent to apply one setting to multiple views. The views cannot use Scope Box, by the way.
Nachricht 3 von 4
anson6WA2Y
als Antwort auf: ToanDN
Propagate 2D datum extents, saves my life! Does that apply to cases other than grid lines?
Nachricht 4 von 4
Levels
