Hello everyone.
I have several instances of the same group in my project, but I need them to be slightly different. Specifically, I need to be able to change the materials of some instances without affecting the others. I cannot ungroup them because I need to still be able to make changes to those instances and I want to avoid making those changes several times to different groups.
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
What about selecting and duplicating each Group instance? This would turn each Group instance into a new, different Group. You could then Edit Group and assign different Materials, assuming the Grouped Elements' Material Parameters are Instance Type Parameters.
Yes, I ended doing just that. Only problem now is that if I need to change anything other than materiais in each group, I'll have to do that 3 times, since now I have 3 different group types. If I had to begin everything over I think it would be more helpful to have the groups modeled as families instead of groups, but I don't think it will be productive to do that now haha
Thanks for the response!
