I have columns in a project that I need to paint
How do I add a parameter to the family so that they will all be already painted when I input them into revit
Regards
Aidan
hi
column family should already have a material parameter. if you want to, you can also change the parameter by instance in the family editor.
if you want different color for your sides, then you will need to create new material parameter for each sides.
You can paint Architectural columns directly in projects without any additional work. For other categories, paint surfaces in the family with material parameters then you can change the material for each surface in projects
You can do this globally by adding the Material to the Column Category under Object Styles. That's what "BYCATEGORY" Materials use.
