The white diagonal area is the side of the roof, I placed a thin layer of interior finish to walls and roof (yellow)..
how can I add the same layer at this place?
-it must be a layer because buildingbook does not recognise paint
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@tareqathamneh6QW84 wrote:
@ToanDN I tried what you said, Roombook resulted in the same values instead of increasing.
same issue I have with the outer sides of the roof
Then add a fascia with the wall's material to the exposed roof edge inside the room, grip stretch it to fit with the room interior, join it with the roof and switch join order so that it cut the roof, then join it again with the wall below.
Roombook doesn't calculate exterior side.
If you're going to use Paint, why not use a Material Takeoff to calculate your Areas?
@barthbradley rules of wall area calculation in Germany; any opening less than 2.5 m2 is entirely ignored and treated as wall area, could not find a way to implement this rule directly, but -Sorry I meant Buildingbook has this option...
but Generally I would have wished it worket without Buildingbook but got no choice
