Appendix B creation in Revit
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
brianwclayton1969
901 Aufrufe, 4 Antworten
What's the best way to create an Appendix B in Revit title block where you can fill out the information? In most cases you can fill out the Appendix B information like a word document and complete the fields. I'm wondering is there a way to fill out this information on the title block without bringing it in as separate sheets. I would fill out the sheets separately and make a legend per sheet and drag to the title block, I know that's the loonngg way. Is there an easier way? I have different states that use different Appendix B forms.
Any assistance is appreciated
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: brianwclayton1969
What is an "Appendix B"? Can you provide an example/screenshot?
Nachricht 3 von 5
brianwclayton1969
als Antwort auf: barthbradley
An Appendix B is information about a commercial building the construction and materials, etc per each state you must provide before design and construction. I have attached pdf and AutoCAD examples.
Thanks for the assistance
Nachricht 4 von 5
ARRGH. Not fun work. I feel your pain.
Look into the plug-ins that are available to import Excel Spreadsheets to Revit Schedules.  There are several at the store.  Trial some for best fit.
....or Link the CAD and call it a day.  Smiley (zwinkernd)
Nachricht 5 von 5
brianwclayton1969
I have a solution from a company that provides a MS exporter.
Thanks for your assistance
