Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community!
This error usually happens when materials are missing in the default rendering library location or library is not installed.
Make sure the library is installed and add the path to the material location to the Additional Render Appearance Paths in Application Menu > Options > Rendering. If there are rendering materials searching for another path, you can add this additional path in the rendering locations as well.
Also, check if the required content is available
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thanks for responding.
I just had IT reinstall my content libraries but the problem remains. I added paths but the problem remains. Although I didn't have to enter paths on the first instal as my cloud rendering worked just fine then, this all happened when IT uninsalledr and reinstall. I am at a stand still and can't move forward and now my project is due. Please help
Hi @Anonymous
Did you try a repair of Revit?
Viveka CD
Hi @Anonymous
Is your issue resolved after a reinstall? Are you able to locate the images?
There may be circumstances where Autodesk Revit products need to be removed from the workstation to allow for a clean installation.
The following in this article will ensure all residual files are properly removed as well.
I look forward to hearing from you.
Viveka CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
Viveka CD
Hi @Anonymous
I haven't heard back from you in a while.
If you need to continue the conversation, please post here and let me know if you have additional questions.
Viveka CD
