Anyway shortcut to delete open tabs?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
remberto.mendoza
1086 Aufrufe, 4 Antworten
At times I have so many tabs opened. Anyway to use a hotkey to close tabs since Ctrl+W just closes completely the project.
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: remberto.mendoza
@remberto.mendoza
You can set one...
GO to Ribbon >> View >> User Interface >> Keyboard Shortcuts and assign the shortcut key(s)...I use ci
OR alternatively if you cant make up ur mind on a shortcut key simply use the button on the Ribbon
OR you could also customize the quick access tool bar and add a shortcut
Nachricht 3 von 5
.. or use this button
Nachricht 4 von 5
That work perfectly! thanks!
By the way is there another shortcut to close some inactive views one by one not all at once??
Nachricht 5 von 5
RDAOU
Wouldn"t the X be faster to close the Active view(s) one after the other?
