The Left is a rotation of 45 on XY plane. Now I need to rate 45 on XZ plane in order to cut the intended model, which is sheared similarly. I am trying to get a poche in my axonometric section.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
@ct_studio wrote:I am trying to get a poche in my axonometric section.
Not clear what this means. Can you elaborate?
This worked! I just have to do a rotation correction on the final sheeted view but I can't get it to rotate increments other than 90.
Which I can do in Indesign/post, but would like to be able to add anotations.
Cut 2 sections. Open section 2 to see section 1 and rotate it 45 degrees.
@ct_studio wrote:Cut 2 sections. Open section 2 to see section 1 and rotate it 45 degrees.
...or rotate a callout. That aside, what is the purpose of this view?
