Any way to get gyp bd clg to be part of floor system?
johnw
johnw
I wanted to create a floor system that would allow lighting fixtures to attach to the underside but cannot without going and adding a ceiling to the room first. Is there any way to create a floor system that shows gyp bd below (the ceiling of the room below) that will allow lighting fixture to attach to it without having to go back and add a clg to the room?
cbcarch
You can add the gyp ceiling to the floor assembly.
You can use face-based light fixtures / or non-hosted fixtures to place on the gyp. bd. "ceiling".
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Well, if you do that then you may need to do this.
How to Convert your Ceiling-Hosted Light Fixtures to Face-Based Light Fixtures:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/conve...
johnw
Thanks. What's the easiest way to change a family from ceiling based to face based?
All fixture under Revit MEP library are faced based.  If you use families from manufacturers then they are face based too.  Only fixture under Architectural library are ceiling based.
I would try those before putting the efforts in converting families.
