Any tool for making walls from CAD lines
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
sandeep_agrawal
3923 Aufrufe, 2 Antworten
Can we have any tool which can help to make walls from pair of lines from CAD drawing in REvit
2 ANTWORTEN 2
Nachricht 2 von 3
cory.simons
als Antwort auf: sandeep_agrawal
Once you have a CAD file or any other file that you wish to trace over and you have selected to create a new wall, go to the modify tab.  In the "Draw" field where your tools are, there is a green line with an arrow and when hovered over will say "Pick Lines".  This will allow you to select lines that you want your wall(s) to trace over.  See below:Picture1.png
Nachricht 3 von 3
For tools you may visit Autodesk app store.
There is one such tool - Make walls. Its description is.
This tool empowers the user to automatically make walls from cad lines in revit. You will be able to create walls in just a fraction of (based on nature of the project) the time it would take a normal Autodesk® Revit® user to complete his/her task.
Link is: https://apps.autodesk.com/RVT/en/Detail/Index?id=6877579131676804491&appLang=en&os=Win64
