any parametric (or dynamo) way to cut/uncut a nested void
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
heichan88
422 Aufrufe, 2 Antworten
I need a nested void to, by parametric way opt to cut or uncut another nested family in the host --- seems there is not yet a parameter to have this choice (cut or uncut), and if by adding a position parameter, there will be an error of "out of host" then the nested void will be deleted.
There are some other indirect ways,, not parametric way, to achieve  the option "cut of uncut" (eg edit family to uncut or copy to another family, add types etc) , but is the current version of Revit which can achieve such fully paramereic way (including dynamo) to achieve that? (opt to cut or uncut for a nested void by parametric /dynamo way)?
If that can be achieved, that will be very facilitative, because a standard block often have various types of nested void to cut/uncut.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: heichan88
You don't reposition the nested family off the host. You only reposition
the void of the nested family off the host.
Nachricht 3 von 3
dingohot
Make a parameter which can move the void so it can cut/uncut the host.
here is one of my old post about it.
http://plevit1.blogspot.com/2013/12/visibility-of-void.html
HyunWoo Kim
