is there any alternative to naviate REX, since it's no more an add-in, and the naviate 2023 is kinda not complete , it can't rebar the footing, only beam wall and column.
thank you
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Why can't you rebar footing? I have no such problem. It's easy, peasy here.
@barthbradley wrote:Why can't you rebar footing? I have no such problem. It's easy, peasy here.
sorry didn't understand your reply
- do you mean you have no problem rebaring footing with naviate?
because i don't have the option to rebar footing in his newer version
- or you mean that it' easy to rebar footing without the naviate addon ?
yes i know it' easy, just wanted to have a tool to make it easier.
thank you
Alternates are:
