I was recently building a family that needed to have mounting heights shown in our schedules & was unable to accomplish this "intelligently".
- What I wanted to happen was to use the 'Offset Height from Level' parameter that is currently used in the Revit Default 'Tag Ceiling Height' & also the 'Tag Top/Bottom Cable Tray' in a security device family but was unable to because it is not available for that type of family.
- I then moved to trying to build a tag that was a modified duplicate of the default 'Tag Security Device' with ANY parameter I could squeeze that 'Offset' number out of, again, not currently possible...
- I finally defaulted to others methods of making a "thin extrusion" in the families mounting point that could be hidden by varying means & then using the Spot Elevation tool to tag the height in plan
It may be a bit redundant for our firm to tag height & device in plan & also want it on a schedule but are we all not trying to make the best models for CD to avoid any possible confusion during the build process? It is all for the sake of BIM anyway.
So. Why can't we, BIM (Titles), use the 'Offset Height from Level' Parameter to integrate into families & more than just two default revit tags?
It would benefit so many intelligent content builders if we were able to utilize this parameter outside of where it currently is. Almost like the 'Default Height' that is included in family creation but then not able to use after the family is placed in a project, it is redundant for me to set that parameter if my colleagues 1: cannot tell that I have already set a default height & 2: Will likely adjust it after the fact with that Offset Height from Level parameter which will then add to what the default height was already set at...
