Anyone noticed the tooltips for the selection toggle tools don't display the shortcut (if it has one) in brackets like every other tool on the interface?
Interestingly, the visual control bar tools don't even provide a tooltip description (let alone an assigned shortcut) is this something worth looking at?
If you hover your cursor over the 'crop view' tool in the properties palette it displays a tooltip description, shouldn't this same tooltip display on the visual control bar button?
Gelöst! Gehe zur Lösung
Gelöst von loboarch. Gehe zur Lösung
Those controls on the view frame are not set up the same way (at the UI level) as the parameters in the Properties Palette and the tools from the Ribbon. There is essentially no "container" to connect the tooltip information to. Getting tooltips there requires a change at the system level (not even sure if it is possible on these kinds of controls?)
Currently this would be classified as "As Designed". A change here would be an Idea Station/Whishlist type item.
