Another wall join problem (three different walls at an angle)
I have three different wall types that should join at the same place. In plan everything works fine, concrete joins with concrete and insulation covers them up. But the two exterior walls have top extension offset and the interior one keeps punching through it, visible in elevations and 3D.
I tried turning wrapping on/off and combination of them, didn't help.
Can't use disallow join then Join command since they're at an angle and the result is weird.
This seems like an angle problem, not wall type problem. The same thing happens even when trying to join two same walls, and the Walls join command simply does nothing to switch them around, which it usually does. The "vertical" one just keeps taking precedence over the angled one.
