This is what I'm getting.
And this is how it should look, but clean. Thin, blue material wall to go up to the red material wall.
I tried every trick I know, joining, unjoining, rejoining, trimming first one than another, changed the blue material to not be structural, changed them to have the same location line, turned off wrapping at ends... Nothing helps, the thin non bearing wall "overrides" the thick bearing one.
I could just disallow join and leave it at that, and if it didn't have so many layers I would, but it look ugly with the layers that it has.
Wall joins command doesn't help either.
Anyone can figure out a proper procedure / joining order to get them to behave?
You could simply Disallow Join with the bottom Vertical Wall and Wrap at the Exterior Ends
@jay_colcombe wrote:You could simply Disallow Join with the bottom Vertical Wall and Wrap at the Exterior Ends
Agreed, but I'd like to figure out if there's a way to do it without disallowing join because this way I have to create another wall type, so there are two identical wall types in project the only difference being one has wrapping turned on and the other one turned off.
Unfortunately as many of the driving parameters for Wrapping are Type Parameter it is often required but i do agree it is not working as i would expect.
