Hello Revit customers on Subscription and Maintenance plans,
Product Updates have been released for Revit 2017.2.3 and Revit LT 2017.2.3 :
Build for Revit/LT 2017.2.3 is 20171027_0315
Patches can be installed from:
RVT -http://up.autodesk.com/2017/RVT/Autodesk_Revit_2017_2_3.exe
RLT - http://up.autodesk.com/2017/RVTLT/Autodesk_Revit_LT_2017_2_3.msp
These Updates target all prior Revit 2017 updates:
All previous updates for Revit 2017.1 and later are replaced by this update and have been expired within Accounts Portal and Autodesk Desktop App.
If you have any questions, please let me know.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Issues resolved in this update:
Annotation
Fixed an issue in which tags moved when a linked file was reloaded.*
Export DWG
Fixed an issue where exporting a sheet with section views to DWG would result in some blocks being shifted away from their correct position in the DWG file.*
Print
Print dialog is no longer disabled when choosing the Print to PDF print driver on a system running the Windows 10 Anniversary Edition.*
Documentation can be viewed from:
RVT Readme
RVT Enhancement Document
RLT Readme
RLT Enhancement Document
Viveka CD
I deeply appreciate you to post the update announcement on this page.
Because I often failed to updating via Autodesk Desktop app as well as I tend forget the place where I can download installer from.
Thank you!
By the way, I just want to ask the translater to modify annoucement in Japanese.
This misleads us to update precivious version, like service pack, update2.2 first, like it used to for Revit2016.
In English, it says Revit2017 "or" so I don't have to worry someone to update straightaway Revit 2017 to 2017.2.3 but
in Japanese it is vague.....
I work for Japanese so I check Revit in both Japanese version and English version.
When I struggle to find solutions for some problems, there are misleading translations like this.
And actually that is not only once in a while.
I know my English is not also perfect but I hope you see my struggle....
I also wonder if I should post this kind of requests in English site or Japanese site.
Anyway, this post will help Autodesk to be aware of difficuties for international users.
Yuki
Thank you and I'm glad to hear that you found this helpful!![]()
I will let the translator know about this and thanks for letting us know!
Viveka CD
Hi @Kiyomi.M
Can you please help out with modifying the Japanese announcement as mentioned by @ysautodesklover in the previous post?
Or else, can you direct me to someone in the Autodesk community who can take care of this issue?
Thank you,
Viveka CD
Hi @Viveka_CD,
Sure, I will post something relevant in JP.
Thanks for bringing this to our attention. Hope to see you in Japanese Revit Forum as well! ![]()
Hi @Kiyomi.M
Thank you so much.![]()
( ありがとう) Arigatou
Viveka CD
Thank you, this update is apparently no longer available with neither the Autodesk Desktop App nor Subscription Account Portal. Luckily, the link you posted above provided access.
Hi @SCOTTGRUHN
Can you try installing the latest Autodesk Desktop App from www.autodesk.com/ada-supportinstall and see if it is listed?
Viveka CD
I have uninstalled Autodesk Desktop App.
Downloaded and installed the latest version via your link - still no updates just "your avaible updates are installed".
Is there a solution for this or do we have to rely on your posts?
Jorgensen
Hi @brj
Thanks for installing the latest version. I'm sorry to hear that the updates don't show up.
Let me see if I can find out more information on why this occurs.
Meanwhile, please try posting to the Autodesk Desktop App Forum for further feedback.
Viveka CD
Hi @brj
Please try the following for me and let me know if this helps resolve your issue:
Sign into your desktop app and click on your user ID (top right corner), click on account details.
Go to my products and click on my access my complete list of products.
This takes you to manage.autodesk.com, where you can see all your installed products and services, then navigate to your product updates - you should be able to see all your updates.
Or you can click on Revit, scroll down and see updates and add-ons like the image below:
Viveka CD
@brj Good to know! Thanks for the update.
Viveka CD
Is this version capable with BIM 360? Based on the forum below, Revit 2018.2.3 installation is required for the next generation of C4R. Does this new C4R also work with Revit 2017.2.3?
Thank you for having this patch linked. I have update my machine to
17.0.1150.0
20171027_0315(x64)
2017.2.3
after which my a360 is no longer available. I am going to use this patch to try and reinsert A360 capability to my revit 2017.
thank you again for providing a possible solution instead of telling me what my revit is supposed to do.
10 mins later--
Applied patch -- uninstalled dynamo -- closed patch dialog -- restarted patch -- installed 2.3 patch - A360 is now available in REVIT 2017.
version in "about" is as follows.
17.0.1150.0
20171027_0315(x64)
2017.2.3
Patch that raised verison to 17.0.1150.0 confused "Dynamo" which after 2.3 patch uninstalled and reinstalled fixed my A360 problem. Now this was a simple fix. thanks again.
