HI EXPERTS,
I created a simple label(sections) with text/annotation, however, I need to change the text/annotation different from the original family once its loaded to the project, is there a way/formula/parameters I can look at to?
Please see below snapshot.
Create a label text and use a shared parameter for example.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Hi RIX and TOAN,
Thank you both, I created the "A" as labels as per your comments but I cant seem to figure out how to make a parameters where I can change the value or annotation so when I loaded the family in my project I only change the text or number?
Please see snapshot.
H.Parayno
Select the generic annotation in view and change the label value via properties, or click on the label in view to edit it directly.
Shown above is a loaded family into the project, does this means I need to create another family so I can edit the "value" in properties without affecting the ones already loaded?
H.Parayno
Out of curiosity, what's the application for this family? How are you using it and what Category is it?
Hi Barth,
I'm using it as section(see below), however there's about 20 elevation's on this drawings so I need to copy the same family but only changing the value?
I'm sorry but I'm new to Revit so please bear with my silly questions.
H.Parayno
