Annotation Tag Gets Family Elevation
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
3122 Aufrufe, 5 Antworten
Hi there,
I am attempting to create a family of Annotation Tag which I hope it to be able to retrieve
the elevation value of families in the project model, but I seem to get stuck now
Please take a look at the attachments to better understand how my problem is
Hope someone can help me out
Thank you,
Nguyen Duy Hoa
5 ANTWORTEN 5
Nachricht 2 von 6
tuuletin
als Antwort auf: Anonymous
Hello, dear,
it is impossible to take parameter "elevation" from generic family to a tag. Thanks, autodesk! Katze (gleichgültig)
But you can create shared parameter "elevation mirror", and copy the value from "elevation" to "elevation mirror" by means of dynamo script (very-very easy to do this).
Nachricht 3 von 6
als Antwort auf: tuuletin
Hello Tuuletin,
Thank you for you answer and sorry for the delay in replying
Yes indeed, as far as I understand, we can programmatically have this task done by means of Dynamo script or Revit API. Just because I wanted to keep it simple possible so that every Revit users can work with. But I seems I have no choice
I finally had it done by Revit API and I think it is worthwhile sharing here for those who are in the same need
And I think this post should be marked as a solution for a conclusion
Procedure:
1. Create a Sharea Parameter named "ELEVATION"
2. Copy value from "Elevation" parameter to "ELEVATION" parameter (this step is programmatically handled by the below code)
3. Create a Tag Family with a label associated with the "ELEVATION" parameter
Thank you,
Nguyen Duy Hoa
Here is the code for handling step 2:
public void TakeElevation(Autodesk.Revit.DB.Document doc)
            // 1. All Generic Instances
            ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_GenericModel);
            IList<Element> instanceList = new FilteredElementCollector(doc).WherePasses(filter).WhereElementIsNotElementType().ToElements();
            // To select and count instances at completion
            IList<ElementId> toSelect = new List<ElementId>();
            long count = 0;
            // 2. Conditioned Instances
            foreach (Element ins in instanceList)
                double elevation = 0;
                IList<bool> flag = new List<bool>();
                bool heightIsAvailable = false;
                bool BasedLevelIsAvailable = false;
                ParameterSet paramSet = ins.Parameters;
                foreach (Parameter param in paramSet)
                    if (param.Definition.Name.Equals("Elevation"))
                        elevation = param.AsDouble();
                // The separation of the two loops is necessary to avoid confusion in taking parameter value
                    if (heightIsAvailable = BasedLevelIsAvailable = true && param.Definition.Name.Equals("ELEVATION")) // "ELEVATION" is a custom instance parameter"
                        using (Transaction t = new Transaction(doc, "Set parameters value"))
                            t.Start();
                            param.Set(elevation);
                            t.Commit();
                            count += 1;
                            flag.Add(true);
                if (flag.Contains(true))
                    toSelect.Add(ins.Id);
            // 4. Report
            if (toSelect.Count > 0)
                MessageBox.Show("Executed on " + count + " instance(s)", "Information");
            else
                MessageBox.Show("No instance executed");
            UIDocument uidoc = new UIDocument(doc);
            uidoc.Selection.SetElementIds(toSelect);
Here is the result:
Nachricht 4 von 6
rodrigo.bezerra
@Anonymous, congratulations on your accomplishment.
Do you mind explain in details how to make it work? Is it a macro? Is it C#? Not everyone of us understand programming.
Rodrigo Bezerra
Nachricht 5 von 6
Sabne
Thanks to share the code. I tried few ways but not working. Can you please explain more when and how run this API code? Cheers
Nachricht 6 von 6
hello, i used this method and i am having an error in the message box like the picture below. anyway i can solve this please?
Tags (3)
