Annotation Set Families with Parameters
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
italonge
1513 Aufrufe, 2 Antworten
Hi everyone...
I'm looking for a way to make my personal Notes Symbols package more practical. In the case, I have several annotation symbol files, each file is an item (Outlets, Electric symbols ...)
This makes my property tab full, so I plan to make a single file with all these annotations to get more practical, and in a way I did (the file I modeled containing all annotations is attached), however in some families I like to have an editable text parameter, nothing less than a text space, which does not even repeat itself, is something free ...
When I use the separate file (only one annotation) this option to edit the text works! However, if I insert this note into a file along with all other annotations, the parameter does not work:
Its a little confuse, so I'm attaching 3 items:
The file with the annotation only
The file with the annotation family (a set of annotations)
And a project file, containing both options ... One works, and the other does not.
Would anyone know how to keep these parameters editable in the Project? I've already researched, and the most I've managed to do is to make a single family ... But the family with the set of several is difficult
Thank you!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: italonge
You just need to add a Label in the annotation family to bring up the label dialog, then add a\one or more instance text parameters to the label. You will also find a host of other goodies such as prefix, suffix, break line between parameters, etc...
Nachricht 3 von 3
italonge
als Antwort auf: ToanDN
@ToanDN I was waiting for you.
Well, seriously... Thank you so much for the help, it was just I make a label into the Set Family and not into the separated annotation family
It's still confuse, but I Hope this help someone else!
