Annotation Problem!!
6 ANTWORTEN 6
Nachricht 1 von 7
Ahmad-Ramadan
610 Aufrufe, 6 Antworten
I only have an access to a few orders in annotation tab in my current project
I don't know what's different between this project and the others !!!
I hope i get the answer
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Ahmad-Ramadan
The view is controlled by a view template, this can limit functionality.
Hope this helps.
Nachricht 3 von 7
Ahmad-Ramadan
als Antwort auf: Anonymous
Thanks for your reply
but, it happened also in this project when i create the view without Applying a view template!
Nachricht 4 von 7
Alfredo_Medina
What version of Revit is this? Looks like a problem that affects the ribbon when a newer version is installed but you use the previous one. This can be corrected by installing the update packages.
Nachricht 5 von 7
Ahmad-Ramadan
als Antwort auf: Alfredo_Medina
Thanks for your Reply
You are right i am using Revit 2015 in this Project and Revit 2017 is already installed in my PC .
but, how can i install update package ?!
Nachricht 6 von 7
If you have Autodesk Application Manager installed just open the app to check any available update for all Autodesk programs you have.
Nachricht 7 von 7
Alfredo_Medina
Or, you can search in the Autodesk website. I found this link, which says that it includes the previous packages:
https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
