I tried to increase annotation line width.
It seems to only be able to increase to .39mm.
After that (limit) nothing changes
Am I correct ?
I might have used wrong term, perhaps line weight or line thickness...
What specific elements do you want to alter the line weight in your project?
@yes_and_no wrote:Am I correct ?
No.
I thought you were talking about annotation lineweights. What do as builts and ducts have to do with your OP?
Those are not annotation lines. Annotation lines are text leaders, tag and symbol lines, title block lines.
@yes_and_no wrote:After that nothing changes
What is this "nothing" that changes?
You really need to do a better job at explaining yourself from the beginning... This is a recurring issue you're having. The fact that you respond with smart*** comments to people that try to provide some help based on the little info you give doesn't help.
You can include disclaimers in your Revit model that clearly state that the model is not to be used for exact measurements to clear up this whole issue.
similar to this, duct lines are single annotation lines (nevermind the dimensions)
- ā
They are NOT annotation lines unless you draw them directly on sheets.
Are you drawing lines over your ducts? I know you said that but I didn't think that you really meant it.
