Hi all,
I have a project were I place different types of components all together, families with Annotation Label Text (lets call them Component A, Component B and Component C)
Then within different sheets I need to show all of the components but not all of the Text (in Sheet "Components A" I need to show all of the components but just the Label text of the Components A)
Normally I would just turn on/off the visibility of the subcategories in Sheet properties, but it is not possible to add subcategories to Label Text. And if I use visibility parameters to the text, when I turn on/off each of them, I does it but to all the Sheets at the same time.
Thank you.
for component A, B and C as 3D families, make a shared Generic Model family with the required text, and nest this family into component A, B or C. For different visibility requirements, make different Family and/or Types.
In the project you can make a filter [ Generic Model, Family and Type ] to turn the text off.
Thinking that it might be possible to make the annotations a group and control the group with a filter, I'll try this and report back
I am an idiot, control it with a filter per category then family name - doh!
