Annotation Family Scale
eman.erfan00
eman.erfan00
I created an annotation family and loaded it in a family, I then loaded this family into the project, the annotation appears way bigger than its size and as it appears in the family although all three files have the same project units
M_Meshal
Hi Eman,
Could you share the family in order to check it?
azad.Nanva
All the Annotation Symbol Tag or ... use the 1/1 scale factor that mean your family size in in the various scale will be change.
you can use the varius size like the example or make the formula for it.
Corsten.Au
Hello
That particular Revit family adjust itself using the scale.
and cause that level head symbol uses only one symbol ( one type of that family ),
It cannot adjust or change as per scale.
see the difference in text when we change from 100 scale to 50... it does it automatically.
Its hard to keep two different sizes in symbol. the whole purpose of symbol is to print at same size
no matter whats the scale of the view.
100 scale, 3 mm text100 scale, 3 mm text50 scale 150mm text.50 scale 150mm text.The level head can use only one type.The level head can use only one type.
Corsten
Building Designer
